Latest: SA01
Overall: 17138
Online Now [117]:
Visitors: 116
Today: 3354
Total: 112173445
Forums › The Car › 206 Problems › 1999 key fob
1999 key fob
vOriginx
PostPosted: Thu Feb 27, 2014 12:29 pm Up
Hello people, I just tried locking my car using the remote locking but It didn't work, I was just wondering what common problems are of the key fobs or if it just might be out of battery?
Cheers!
Razor34
PostPosted: Fri Feb 28, 2014 2:38 am Up
Probably just the battery so change it and problem will more than likely be solved
Ray
vOriginx
PostPosted: Fri Feb 28, 2014 3:53 am Up
Okay actually got a new problem... The remote locking is working again but when I lock my car at night etc and leave it for a long period of time, I'll come to my car in the morning and it'll be unlocked which isn't ideal! Anyone had this problem before? Car not staying locked, even using the key itself it still unlocks Itself.
Seatock789
PostPosted: Fri Feb 28, 2014 4:50 am Up
From experience it could be either:-
1> Bouncing door locks - Sometimes when you lock the car the locks will bounce back up although this generally happens straight away. This is solved by replacing which ever door actuator is causing the problem.
2> Someone is accidently pressing the key fob causing the doors to unlock
3> Some weird electrical problem.
vOriginx
PostPosted: Sat Mar 01, 2014 9:35 am Up
yeh the door locks do sometimes bounce back after locking them straight away. But obviously when they do lock properly they are bouncing back randomly.. Hmm
