Latest: Andyblue64
Overall: 17123
Online Now [127]:
Visitors: 126
Today: 59617
Total: 98814585
Forums › The Car › 206 Problems › Central Locking Bouncing Problem
thegasman
PostPosted: Fri Feb 28, 2014 2:16 pm Up
Hi there, i have just acquired a 206 as a first car for my partner to learn to drive in; its a 2000 w reg 1.4
Had the car a few weeks and the car doors refuse to lock, every time the central locking button is pressed the car locks and then bounce back up.
The only way to lock the car is to click the central locking button a few times and lock each door manually. I have also noticed that the boot now stays unlocked and wont lock.
Any help or guidance would be much appreciated.
mtempsch
PostPosted: Fri Feb 28, 2014 3:23 pm Up
Any help or guidance would much appreciated.
Probably failure of one (or both) lock mechanisms.
IIRC, unplug one door lock at a time and see if the still connected door and boot starts working. If so, replace the unplugged mechanism.
Not sure if the boot lock can cause this...
Silvermetallic 2004 206 RC
Seatock789
PostPosted: Sat Mar 01, 2014 3:54 am Up
Sounds like 1 of the door actuators have gone and needs replacing, easy but fiddly job as you have to strip the door. Once you find out which one it is, look for a replacement on ebay but be sure you get the right one as there are a few different variants depending on the number of wires on the plug. I think from memory there is a 6 wire version, a 9 wire version and something else.
Once you've stripped the door or boot, look on the inside where the lock is, you'll notice that the is a plug that connects to the lock mechanism, take the plug out (hardest bit I found) and take a picture of the connecter and then you'll know which version you'll be looking for. I priced a new Peugeot item up and it was about £80, got one off ebay for £10 in postage and so far it's worked fine.
thegasman
PostPosted: Sun Mar 02, 2014 11:26 am Up
Stripped both doors and the boot door and disconnected each of the lock mechanisms individually and still getting the same fault with the locking bouncing back up. I can't see any other indication of what might be causing the problem.
thegasman
PostPosted: Sun Mar 02, 2014 1:53 pm Up
Just a thought, is it possible that both door actuators are faulty?
DREWDEN
PostPosted: Sun Mar 02, 2014 3:59 pm Up
A common fault is a break in the drivers door wiring loom beeween the A pillar and the door, worth inspecting.
206 2ltr Hdi glx 53 plate
