Latest: Worthy967
Overall: 17143
Online Now [563]:
Visitors: 562
Today: 146362
Total: 114269846
Forums › The Car › 206 Problems › 206 gti passenger side door stuck shut
DAVEY3478
PostPosted: Sat Mar 01, 2014 7:43 am Up
Can anyone help passenger side door stuck closed think motor has gone, when I try to lock car with key fob the boot and drivers side door just bounce back open passenger side button on door is up all the time I've took passenger side seat out and pulled door card off as best I can but can't get door open anyone had this problem or know what to do??
206 GTI
Seatock789
PostPosted: Sun Mar 02, 2014 4:29 am Up
I had this happen to me a couple of years ago on a different car, unfortunately I ended up denting my car and having to replace the whole door.
You could try giving it a good kick whilst someone tries to open it from the outside. Failing that try using a prybar to open from the inside, use a block of wood or something to stop you damaging the inside.
I think even if you took it to a garage they would resort to the same methods.
