Posted: Sun Mar 02, 2014 8:10 am |
any tips on how to fit a cat to a gti180. looks like the manifold clamps gonna be hard to get too.
Posted: Sun Mar 02, 2014 12:00 pm |
I recommend that they be done by prof. as it's not an easy to job to be done by yourself.
Posted: Sun Mar 02, 2014 12:01 pm |
Clamp is easily accessible from underneath.
Posted: Sun Mar 02, 2014 1:38 pm |
I found it tight to get to but as mentioned from under the car is easiest way to get to the clamp. I had mine on axle stands.
Posted: Sun Mar 02, 2014 2:24 pm |
The clamp definitely wasnt easy to get to on mine, from underneath or above! There is really not a lot of room and if the clamp is in the same position as mine was you'll be there for a while haha. But just stick with it.
