Latest: eionpeu
Overall: 17120
Online Now [68]:
Visitors: 67
Today: 16071
Total: 97264160
Forums › The Car › 206 Problems › clutch cable.
clutch cable.
gizmothedog
PostPosted: Thu Feb 20, 2014 3:06 pm Up
just wondering how long a clutch cable would take roughly?
anyone done one on a 1.4 8v?
PostPosted: Fri Feb 21, 2014 6:25 am Up
Quite a few things to take off but 30 - 45 mins for a DIY and someone who has done it before maybe less if you want to see how quickly it can be done.
The b***h with the clutch cable id getting it on and off the pedal. It really is tricky and you must have long thin fingers. Short fat fingers won't do it. I have done it lots on my daughter's car and can get the cable on and off in seconds but the first time was over half an hour just to get it off the pedal.
gizmothedog
PostPosted: Mon Feb 24, 2014 2:45 pm Up
thanks,
im going to have a go on thurs but my fingers don't fit into the short and thin catergory
should be fun....
PostPosted: Fri Feb 28, 2014 1:33 pm Up
Any luck getting that cable changed?
gizmothedog
PostPosted: Fri Feb 28, 2014 1:35 pm Up
Not atempted it yet mate. Think ill do it next weekend.
PostPosted: Fri Feb 28, 2014 10:10 pm Up
By the way - long thin fingers not short thin as your penultimate post.
gizmothedog
PostPosted: Tue Mar 04, 2014 2:37 pm Up
just before I do change the cable, any advice?
symptoms are struggles to go into 1st and reverse while parked. been advised that the clutch maybe on the way out and that changing the cable MIGHT make the clutch slip. any ideas or similar problems?
RockRulz
PostPosted: Tue Mar 04, 2014 4:03 pm Up
Mine was similar....changed the cable...no difference. Good luck with yours. Smile
www.facebook.com/Hazel...rington151
PostPosted: Wed Mar 05, 2014 10:08 am Up
Cable change is probably not the fix. Also if you fit the cable to a car with worn clutch it will adjust itself to that wear and can't be reset so when you then fit a new clutch it is another new cable.
gizmothedog
PostPosted: Sun Mar 30, 2014 2:51 pm Up
just a little update....
I decided to check the oil level in the gearbox today,
when I removed the filler plug there was no evidence of oil.
I had bought a 1 litre bottle of oil to top it up if needed.
it took the whole 1 litre and still no signs of it overflowing through the hole, so I nipped out and bought another litre.
it took another 1/2 litre until it started overflowing.
needless to say the gearbox works much better, still not 100% but a hell of a lot better.
