Latest: Andyblue64
Overall: 17123
Online Now [273]:
Visitors: 272
Today: 90080
Total: 98601394
Forums › The Car › 206 Problems › Warning lights intermittent
W573ADS
PostPosted: Sun Mar 09, 2014 6:23 pm Up
Hey guys I've got a new 206 Smile
I've gone and got a y reg 206 GTi (138),
The problem I've got is mainly when I turn into Islands at speed my battery light and oil light flicker on sometimes when just sitting still aswel
Any ideas guys?
PostPosted: Sun Mar 09, 2014 6:26 pm Up
Are you revs dropping at the same time? Might be worth checking the battery connections. One of the common things to go is the earth lead where it connects to the gearbox.
PezHdi
Loose connection somewhere?
Check battery straps and earths.
EXL Pez
W573ADS
PostPosted: Sun Mar 09, 2014 6:51 pm Up
Nice one guys thanks for the rapid response, will be having a look tomorrow at work as I've got to do all round brakes, I've seemed to cook the front discs,
Has any of you done the brembo 4 pot conversion from the 406 v6 as I've got the calipers knocking around and might do the upgrade next time they need doing, also any hints and tips about the car and improvements would be much appreciated Smile
PostPosted: Sun Mar 09, 2014 6:55 pm Up
I'd check the oil level just in case.
W573ADS
PostPosted: Mon Mar 10, 2014 3:35 am Up
Oil level is all good Smile
PostPosted: Mon Mar 10, 2014 12:45 pm Up
if the oil lights flash in a constant rate,then you got to check 2 things:
1-Oil filter
2- Oil Sump,as it might have be hit somewhere,which cause the oil pump to have poor sucking.
