Online Now [482]:
Visitors: 481
Today: 73683
Total: 142217823
Forums › The Car › Request a how-to › Angel eyes connection
Forum IndexRequest a how-to
ch4c4
PostPosted: Fri Oct 04, 2013 2:09 pm Reply with quote Up
Hi i just bought these off ebay and they come with two wiring options as you can see on pictures.
My car is pre plexed 1.4 LX from 2000 if i connect the lights using this will they work fine? I was reading some info about relays etc but i didnt understand anything as i dont understand anything about electrics.
Can anyone help?
jbhoy90
PostPosted: Tue Mar 18, 2014 6:32 am Reply with quote Up
Hi,
I had the same problem when i bought a pair from Ebay, i took the original headlights out only to find i had no idea how to fit them :P, take it to an auto spark is your best bet, probably only charge you around £20 at most!
make sure they are the right ones for your car mine had to have the connectors changed and didnt work with my leveling motors, i am actually changing mine back o the crystals once a have masked them as the light output on the angels isnt great.
jbhoy90
PostPosted: Tue Mar 18, 2014 6:37 am Reply with quote Up
plus they dont fit as neatly with the body work as the originals but thats only noticable when your up close, always bugged me though
PostPosted: Tue Mar 18, 2014 9:14 am Reply with quote Up
One of the two looms you have will work fine. If one don't plug in try the other, you don't need to worry about relays etc with them.
Pugvanharry
PostPosted: Sat Mar 29, 2014 4:15 am Reply with quote Up
Hi my angel lights are in a case and have 3 red wires and 3 black wires on each head unit, h1 on the angel and h7 on standard ? How on earth do I wire them?
  Quick Reply
Username:
Message:
Quote the last message
