Online Now [604]:
Visitors: 603
Today: 114297
Total: 157136049
Forums › The Car › 206 Problems › Battery dies when turning key
nemesislee
PostPosted: Wed Mar 19, 2014 8:04 am Up
Ok this one is confusing me,
open the car using central locking everything is fine. go to turn the car on lights come on then as soon as i go to start the car lights all go dead and nothing not even a flutter of ignition.
weird thing is is that i opened my bonnet and could not see anything wrong so i thumped my battery is anger :). thus doing this the central locking started to work again.
i close the bonnet and think wahey ive fixed it, ..... it happens again :s
so i do the same again open the bonnet thump the battery but this time leave it open until i try to start the car which works this time Smile
but it keeps happening Sad i did notice that i have a whirring noise when revving but thought this was sue to spraying it with belt slip spray.
and ideas would be great
thanks
peugeot 206 silver 1.4ltr lx
20Drift
PostPosted: Wed Mar 19, 2014 8:13 am Up
Check your battery earth - make sure it's got a good connection to the battery and there is no corrosion either end of the lead.
Also, check your earth strap to gearbox, as these are known to perish over a while
nemesislee
PostPosted: Wed Mar 19, 2014 8:40 am Up
i'll check that Smile bloody thing , although is funny when the try hitting it test works Smile lol
nemesislee
PostPosted: Wed Mar 19, 2014 9:49 am Up
Ok so i checked my earth lead coming from the battery its quite loose so im hoping that tightening that up with help the issue
thanks
PostPosted: Wed Mar 19, 2014 2:57 pm Up
thanks
Well since the Earth lead is loose,then it's the cause of the problem,as when you try to start the car,there is a heavy load on the battery,and the (+) and (-) terminals,so if you have a loose one,that means poor connection,and you will have a very hot lead which is something dangerous and risky to have,and can cause serious damage to your car ECU and BSI,so make sure you tight it well.
nemesislee
PostPosted: Wed Mar 19, 2014 4:05 pm Up
Tried tightening the connection and can't tighten it anymore:( it's still loose, any suggestions ?
20Drift
PostPosted: Wed Mar 19, 2014 8:35 pm Up
Get a new earth lead, or change the connector on the end to fit your battery
