Latest: Mr-Koekwaus
Overall: 17125
Online Now [110]:
Visitors: 109
Today: 18097
Total: 99928637
Forums › The Car › 206 Problems › Squeeking from the front D/S wheel.
Vexs
PostPosted: Sun Mar 23, 2014 3:52 pm Up
On my way to work this evening encountered a squeeking noise coming from the front drivers side wheel. Havent had time to really look to see if there's any problems, but any common faults I should perhaps look in to?
It seems to only occour when turning left and completly stops when the wheels are straightened up or turning right. Confused
Also worth noting had the brakes and discs replaced about a month ago, so unlikey to be the problem and defiently not mistaking it for any of the belts as these where all changed about 2 months ago.
Thanks in advance!
PostPosted: Sun Mar 23, 2014 4:04 pm Up
If your brakes were only replaced a month ago, then could be down to them not being bedded in properly. Mu other thought would be to jack it up and see if there is any play in the wheel bearing
luke079
PostPosted: Mon Mar 24, 2014 12:52 am Up
Check to see if your brakes are binding does sound like that Smile or as Macca said bedding in
PostPosted: Mon Mar 24, 2014 9:01 am Up
Also look to see if there is antisqueal grease on the rear of the brake pads. It can be any colour but you ought to be able to see some sign of grease like substance on the rear of the pads. It should be a very thin film not a thick application so look closely.
Changing pads without this can be a routine cause of squeal.
Vexs
PostPosted: Mon Mar 24, 2014 1:17 pm Up
Thanks for the advice guys much appreciated.
My GTI 180
My Old 1.4 8v
