Latest: heikkisj
Overall: 17126
Online Now [118]:
Visitors: 117
Today: 19405
Total: 100255692
Forums › The Car › 206 Problems › Looking for MOT fail opinions.
Dulayne
PostPosted: Wed Mar 26, 2014 11:48 am Up
I got my 206 last year and it failed it's MOT in May. I have kept the engine turning over so it has not just being laying around. The engine is sound, starts great every time and the oil level is fine too.
I only recently pushed to start getting the car sorted out, there are a lot of little things that are easy to replace but I just want some opinion on the state of the car, based on the image I have attached.
Note the outer sil problem is nothing major just the garage overstating the problem imo.
The tailgate is a problem I think is to do with the latch as it won't shut unless the little pin is moved up a little. As a result the central locking won't stay locked via remote. Resetting it does not work so I may need to replace the latch on the boot itself?
Am I in over my head too much and what jobs could prove to be the most costly? I really do not want to give it up. Any thoughts would be appreciated. Smile
Thanks!
iainlovatt
PostPosted: Wed Mar 26, 2014 12:05 pm Up
i have never seen a mot refusal list that big before.
Thats a lot of work and will cost a fair amount too,
IMO its not worth the hassle,
(My Garage)
Dulayne
PostPosted: Wed Mar 26, 2014 12:09 pm Up
Out of all of the problems with it, what would you say are the costliest and how much would you say I am looking at paying? I have a good friend who would be able to help me get the car sorted out but I have not spoke with him yet about it.
PostPosted: Wed Mar 26, 2014 12:40 pm Up
Speak to him Smile
Dulayne
PostPosted: Wed Mar 26, 2014 12:43 pm Up
E5GDM wrote:
Speak to him Smile
Of course I can do that, I was just looking for some opinions on the work involved. I am a newbie to car repair etc.
PostPosted: Wed Mar 26, 2014 1:00 pm Up
Looking at the list, it doesn't look too bad to me, but to someone else it will look like the car is falling to bits and needs major surgery.
Is it worth doing? On a 2007 car yes, on a 1999 model, no.
It always baffles me why people present a car for MOT with so many obvious faults in the first place, but then to leave it almost 12 months before bothering about it....
Now to get it through a test you will probably have to do the advisories, whereas if you had done the failure work straight away, you could prioritise the advisory work over the next 12 months, spread the cost and the time.
Dulayne
PostPosted: Wed Mar 26, 2014 1:51 pm Up
Sadly you have me there, money and other things made it hard. That is my fault and problem though. You make some good points macca, I am looking to get another car sometime next year when my finances will likely be much better, so getting this sorted out is the only "realistic" option available to me.
The car drove and handled well, no creaks whines or anything major (apart from the exhaust needing work/replacement due to it purring like a kitten with a cold).
Anthonys206
PostPosted: Wed Mar 26, 2014 2:59 pm Up
My car was the exact same. I bought a 52 plate 1.4 2 years ago as my first car. I bought it knowing it was an mot failure but that didn't really bother me considering I had all the time in the world to put it right while my insurance came down. Anyways it's had new wishbones and driveshafts, steering rack, drop links, discs and pads, cambelt, crankshaft oil seal, clutch, brake pipe, lambda sensors, cat, tyres, wipers, battery, driver's side hub. The car had its mot yesterday and it failed only to be passed half hour later!
gizmothedog
PostPosted: Wed Mar 26, 2014 3:33 pm Up
I cant see the picture, what reg is the car?
ukskater01
PostPosted: Wed Mar 26, 2014 5:52 pm Up
For someone that knows what there doing I don't think it would take that long to sort out. You need some bulbs replacing, looks like a new exhaust from the cat back or just some new clamps. Have a look at the shoes and adjust or replace, replace or unseize the brake load sensing valve. It would be quicker and easier to replace the drive shafts than replace the cv joints unless the joints are ok,if they are then just regrease and put new gaiters on.The boot latch might just need adjusting, then you will need two tyres and maybe the tracking done after you have replaced the anti rollbar links. Get the headlights adjusted by the garage before the test and you should be good to go. The oil leak your friend will have to look at, could just be the filter or rocker cover gasket has perished and needs replacing.
Dulayne
PostPosted: Sat Mar 29, 2014 7:45 pm Up
Ahh thanks for your insight into all of that, I guess all of the work if I were to get it all done by a garage would cost a fair bit. What do you think would be the costliest to work? I am guessing the exhaust and suspension/cv stuff?
ukskater01
PostPosted: Sat Mar 29, 2014 7:51 pm Up
Yeah the exhaust is gonna set you back around £100 depending where you get it but you never know you might get away with new clamps depending on the condition of the old exhaust. You could always just get a quote for the work, you don't have to get it done at that garage though.
Dulayne
PostPosted: Sat Mar 29, 2014 8:13 pm Up
Yeah the exhaust just sounds like a patch up and tighten jobbie. It was the anti-roll bar stuff and other things that made me wonder.
Andy206
PostPosted: Sun Mar 30, 2014 4:53 am Up
Easy way to look at this situation is the cost, how much would it cost to get though the MOT and how much to buy another with a new MOT...sometimes better the devil you know Smile
Dulayne
PostPosted: Sun Mar 30, 2014 11:54 am Up
Yeah this is the kicker, the car drove and handled fine. It would stop without any ill feeling from the brakes, would not roll back so the handbrake must just need adjusting. Exchaust has just got to be a case of patching up and connecting (if a replace is not required). Of course there is the other stuff.
