Latest: Mr-Koekwaus
Overall: 17125
Online Now [76]:
Visitors: 75
Today: 26942
Total: 99358927
Forums › The Car › 206 Problems › un-even running
un-even running
bedfordft
PostPosted: Mon Mar 31, 2014 11:51 am Up
hi I hope someone will be able to solve this my wifes 206 has very rough tick over its tick over speed is about 800 rpm the rev counter does not move but the tick over is rough. any thoughts?
PostPosted: Mon Mar 31, 2014 11:52 am Up
when was it last serviced?
bedfordft
PostPosted: Mon Mar 31, 2014 11:53 am Up
about 1000 miles ago
PostPosted: Wed Apr 02, 2014 2:37 am Up
Age, engine size and diesel or petrol would help!
Any mods on the car and if petrol 8V or 16V?
Do you have an itemised list of the work done at the service?
bedfordft
PostPosted: Wed Apr 02, 2014 12:32 pm Up
hi its an 03 plate, petrol, 16v oil, oil filter, plugs, air filter,
206gt160
PostPosted: Wed Apr 02, 2014 4:38 pm Up
Try cleaning the throttle body and the sensors on the throttle body, could also be a clogged up ICV that needs cleaning
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
PostPosted: Thu Apr 03, 2014 1:08 pm Up
It could be compression down, failing spark plug, failing injector, air leak on inlet, failing MAP sensor. If it happened immediately after or very soon after the service then it could be one of the new plugs is defective or one of the recirculating air pipes is dislodged or split.
A quick check to find which of the cylinders is misfiring, if it is a single failing cylinder problem, is to buy an infra red thermometer and measure the temperature of each exhaust manifold branch and the one misfiring will be significantly cooler than the rest.
