Posted: Sat Mar 29, 2014 4:44 am |
Good Day All.
I have always been a turbo petrol guy, But I have now turned to the dark side .
Most cars that I have worked on being turbo petrol have had both MAF and MAP Sensors fitted.
One of the 1st things I did to my Peugeot 206 LX 2.0 HDI, was to connect up my OBD2 reader to check for any faults, etc.
When running the OBD2 realtime data viewer, One of the things I noted was that the Manifold Pressure (MAP) never changed even if the engine was running or not.
Can anyone please confirm for me if the Peugeot 206 LX 2.0 HDI has only a MAF Sensor or if it also has a Manifold Pressure (MAP) Sensor.
If it does also have a Manifold Pressure (MAP) Sensor where is the sensor located?
Thanks for your time.
Best Regards.
Posted: Sat Mar 29, 2014 2:23 pm |
Hello and welcome to ,can you provide your last 8 digits in your VIN,so we can be sure what sensors your car got
Posted: Mon Mar 31, 2014 3:01 pm |
Thanks for your reply.
The last 8 digits of the VIN are: 41077520.
Best Regards.
Posted: Thu Apr 03, 2014 11:54 am |
Is anyone able to advise me on my above question?
Posted: Fri Apr 04, 2014 1:26 pm |
Hello,sorry for late reply,but I was busy,and couldn't get online to post a reply,after checking the service box you have a MAF,as you got a flow meter after the air filter,here what you got according to your VIN.
