Latest: williamekstrom
Overall: 17124
Online Now [109]:
Visitors: 108
Today: 20262
Total: 99352256
Forums › The Car › 206 Problems › new Stereo help needed
pedrovski
PostPosted: Thu Apr 03, 2014 2:25 pm Up
Hi, i have just bought myself a 2002 hdi 206 which had the standard stereo and have replaced the stereo for an lg one which i hooked up with the adapters and it worked fine so i fitted the stereo properly and now having problems getting stuff working, ive taken it back out and there is nothing shorting or anything. the lights on the buttons are lit but there is no power the live for the stereo. at the same time this happened the display in the middle of the car stopped working properly and now resets every time the car is turned of and back light doesn't work on it and from reading it solves alot of issues like this i have tried resetting bsi which hasnt done anything so any help would be greatly appreciated. thanks
20Drift
PostPosted: Thu Apr 03, 2014 2:29 pm Up
Switch the yellow and red wires around
pedrovski
PostPosted: Thu Apr 03, 2014 2:53 pm Up
would that be whats causing the centre console from not working properly? the stereo did all work fine till i actually secured it all properly
20Drift
PostPosted: Thu Apr 03, 2014 3:24 pm Up
Ah misread it - so what isn't working? The MPG display and clock and everything?
pedrovski
PostPosted: Thu Apr 03, 2014 3:29 pm Up
i'll try swapping the yellow and red wire but yeh the display with the clock on, it resets when the ignition is turned of and there is no backlight.
