Latest: slaapkonijn
Overall: 17169
Online Now [116]:
Visitors: 115
Today: 66507
Total: 128659067
Forums › The Car › 206 Problems › Engine rev problems after warm start
majormajor
PostPosted: Sun Apr 06, 2014 1:56 pm Up
Dear 206 experts,
Here's a problem that has been bugging me for a while with my otherwise perfectly functioning Peugeot 206 (W reg, 1.4i petrol engine, about 56k miles on the clock).
When I start the engine from cold, the car behaves itself and everything is as it should be. Engine revs is proportional to how much I press the accelerator, idle rev is normal, the car runs perfectly smoothly. However, if I turn off the engine for a few minutes (for example, I stop to fill up with petrol) and then re-start it, something weird happens. To start with the idle rev is normal (or maybe a bit too high but not excessively), but as soon as I rev up the engine to something like 2000 rpm, the revs gets stuck there and only decreases very gradually. The car "drives itself" and there seems to be a power surge: the throttle response becomes very sharp. Then, gradually within a few minutes everything goes back to normal again.
As I tend to do long trips mostly, the problem is not something I can't live with, but it can get annoying.
One of my colleagues - who happens to have an identical model - suggested I check the idle valve. I took it out and cleaned it out thoroughly but it made no difference.
If any of you have any suggestions, please could you share your thought with me.
Hawkers
PostPosted: Sun Apr 06, 2014 3:34 pm Up
Is this what you cleaned?
www.206info.co.uk/Foru...ottle.html
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
majormajor
PostPosted: Mon Apr 07, 2014 4:44 am Up
Not the whole caboodle, only the idle stepper motor (the item shown in Step #13 of the guide). It was sooty but not sticky.
PostPosted: Mon Apr 07, 2014 6:26 am Up
If it has one check throttle position sensor and map sensor.
Also I had one play up similar due to a faulty temp sensor.
PostPosted: Mon Apr 07, 2014 8:16 am Up
1.48V is, I think, combined MAP and temp sensor (MAPT). My money would still be idle steeper motor and / or throttle body.
PostPosted: Mon Apr 07, 2014 3:35 pm Up
Do what you saw in the how to thread,and see how it goes,if that didn't help to fix it,then you need a new stepper motor.
