Posted: Tue Apr 08, 2014 12:16 pm |
Alright guys
This morning I notice that my clock display on my Peugeot 206 2001 was very faint , could hardly see the time at all in daylight and now it has completely died on me..
I got told that it was the bulbs in it going.. But I have just taken the clock display out the car and looking at I can't see any bulbs in it..
Posted: Tue Apr 08, 2014 12:54 pm |
Hello there,
I had this happen, the display went really faint and because there was no light coming from behind it you couldn't see it at all in the dark.
Here's a picture of the back of the display and the 3 bulbs twist out.
FYI: £1.50 for 3 new bulbs from Peugeot. For that price i replaced all 3 instead of going through trying to find out which individual one it was.
Hope that helped.
Regards, Richard.
Posted: Tue Apr 08, 2014 12:55 pm |
There are backlight bulbs that are held in by bulb holders that twist then pull out.
Being a 2001 model I would guess it's non plexed as the clock displays on these the solder joints can break inside cutting of the power to the backlight bulbs.
Posted: Tue Apr 08, 2014 1:00 pm |
| RichardEke wrote: |
Hello there,
Hope that helped.
Regards, Richard. |
I have different display clock than the picture you have showed me.. I got a 2001 hatchback model..... I've got one similar to this one www.ebay.co.uk/itm/191...1423.l2649
Posted: Tue Apr 08, 2014 1:07 pm |
The white bit in middle is the bulb holder, twist it & it should release.
Posted: Tue Apr 08, 2014 1:13 pm |
| MrBSI wrote: |
| The white bit in middle is the bulb holder, twist it & it should release. |
Thanks for that.. So I should now be able to get a blue bulb for that
Posted: Tue Apr 08, 2014 1:30 pm |
| byronwells wrote: |
| MrBSI wrote: |
Thanks for that.. So I should now be able to get a blue bulb for that  |
You can BUT it's not that simple to change the colour
There is an orange filter inside the display that makes the colour, the normal bulb is clear.
Posted: Tue Apr 08, 2014 2:56 pm |
| MrBSI wrote: |
| byronwells wrote: |
| MrBSI wrote: |
There is an orange filter inside the display that makes the colour, the normal bulb is clear. |
Oh darn lol
Posted: Wed Apr 09, 2014 4:38 am |
| byronwells wrote: |
I have different display clock than the picture you have showed me.. I got a 2001 hatchback model..... I've got one similar to this one www.ebay.co.uk/itm/191...1423.l2649 |
There are two types: one basic one and one with extra lines for temp etc. And there are two systems ... which means there are FOUR MFDs around! Some had three bulbs, some have four.
Pre-plex and mux/plex don't mix!
Posted: Wed Apr 09, 2014 11:19 am |
| gazza82 wrote: |
| byronwells wrote: |
Pre-plex and mux/plex don't mix! |
OP has got the bog standard poverty spec CLOCK with 1 backlight bulb, its not an MFD on OP's car.
Also there are a lot more then 4 MFD's
