Latest: Mr-Koekwaus
Overall: 17125
Online Now [132]:
Visitors: 131
Today: 40051
Total: 99425214
Forums › The Car › 206 Problems › com 2000 identification
gibbo300
PostPosted: Fri Apr 11, 2014 9:58 am Up
hi all, how do i i identify the unit that should be fitted bto my car? is there anyway i can find out the exact unit that should be fitted. the one that is in there has the following numbers on it.
345 724 83
96605910XT
4378-E1
20 juin 2007
also on another label is ZA700432
and the words COM 2000 DAV
i assume DAV is the manufacturers name?
the car is a 52 plate 1.1 look, but i guess it has been changed at some time due to the date of 20 juin 2007 on the label.
for this reason i dont know if this is the one that is correct for the car.
out of all the numbers on the stickers which one tells me the exact unit that is fitted at the moment? is it the 9660591xt?
also i assume there should be 3 connections to the airbag, the black plastic cables that have the white cable running through the middle and is connected to the top of the comm unit just above the steering column hole.? 2 of these seem to have been cut off.
PostPosted: Fri Apr 11, 2014 12:47 pm Up
There should be 2 yellow plugs & then a grey plug on the cables that stick out the front of a 206 com unit.
The 2 yellow plugs ( 1 with blue insert & the other with green insert ) are for the drivers airbag ( its a dual stage airbag so that's why there are 2 plugs )
The grey plug is for the horn.
gibbo300
PostPosted: Fri Apr 11, 2014 1:48 pm Up
thanks D, i have the grey plug but the horns not working, the other 2 plugs have been cut off. any ideas on the other questions in my original post?
