Online Now [465]:
Visitors: 464
Today: 155000
Total: 157176398
Forums › The Car › Request a how-to › Fitting 4-1 race manifold (engine management )
Project2062014
PostPosted: Mon Apr 07, 2014 10:25 pm Reply with quote Up
hi. Whats the situation with .fitting a 4-1 with one sensor fitment .then fitting a de-cat pipe with one sensor fitment as well . no flex joint ? Is it possible to reset? the engine management if the light comes on remapping the car ? I am wanting to install a race manifold off fleabay & do not want any M.O.T issues or engine . maybe make two pipes ? with cat no cat ? get the cat welded in ? can anyone please help me ? Cheers B
Ryan324
PostPosted: Tue Apr 08, 2014 7:52 am Reply with quote Up
i have a 4 into 1 stainless manifold and stainless de-cat pipe on my 1.6 8v with single lambda sensor into the manifold and it all works very well never had an issue with engine management lights etc not sure if this applies to other engine sizes...
Project2062014
PostPosted: Tue Apr 08, 2014 11:31 am Reply with quote Up
Im going to get a flexi joint and keep the cat !! cut n weld !! done! with sensors and good 4 M.O.T .
Mr-Tigger
PostPosted: Tue Apr 08, 2014 3:09 pm Reply with quote Up
it may set off the eml if you fit the fleabay ones as the lambda sockets are not angle-adjusted to compensate for the difference the lambdas should pick up in exhaust gases between the two points.....doesnt effect performance at all though,no limp mode because of it........just a pretty dash
Project2062014
PostPosted: Fri Apr 11, 2014 3:30 pm Reply with quote Up
how sure are you ?
206gt160
PostPosted: Fri Apr 11, 2014 4:30 pm Reply with quote Up
Wouldn't bother with flexi pipes they will always end up leaking down the line
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
usher
PostPosted: Sat Apr 12, 2014 5:24 am Reply with quote Up
it wont work without one you will eiher damage the head or manifold
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
206gt160
PostPosted: Sat Apr 12, 2014 7:52 am Reply with quote Up
I dont have a flexi with my 180 manifold and decat.
206gt160
PostPosted: Sat Apr 12, 2014 9:32 am Reply with quote Up
Muat be different with an aftermarket 4-2-1. Im almost certain mine was the 180 manifold and not an aftermarket one
Project2062014
PostPosted: Sun Apr 13, 2014 3:34 am Reply with quote Up
flexi is needed .will last a few years .. 2 1/2inch flexi over the cat pipe im going .. 4-1 manifold long pipes on it for better flow . as for the sensor angle adjusted .grind the socket down where it sits until the gasses flow across the sensor. simpols ..
usher
PostPosted: Sun Apr 13, 2014 1:11 pm Reply with quote Up
whats the issue with the sensor as mine went in with no mods etc and has worked fine ever since
project thread WIP
garage
FAQ
206 gti firedance
Project2062014
PostPosted: Wed Apr 16, 2014 1:43 pm Reply with quote Up
What size flexi did you use ? I've got 2 1/2 inch and a 61mm pipe to weld up , do you have the cat on ? Going to Cut cat pipe down flexi should fit over the pipe , weld up then 61mm pipe to the manifold pipe,that slots inside. The one holds the gasket , ,got new studs and bolts for manifold just incase ! On it 2mz ,, ! Whoop whoop ! No problem as of yet , just checking with ppl that have done it successfully so I know of any issues ,cheers B ,
Project2062014
PostPosted: Thu Apr 17, 2014 3:28 pm Reply with quote Up
It's fitted no flexi all new studs & bolts with cat ,The exhaust lower gasket that came with manifold and the two bolts didn't fit it ! Took me 9 hrs straight ! Back box is blowing & the new water pump is leaking from sum where so all back off to find the leak tomorrow , FFs , all running fine , drinking the juice was ok after remap , new throttle body & cambelt & it's defo drinking . Any info on the water pump leaking would be great , down side to the manifold is I've lost most of my backfire power , it's not poping and banging any more , did until 5 miles down road , it has stopped ,was a sharp crisp gun shot a couple every down shift !
usher
PostPosted: Fri Apr 18, 2014 1:54 am Reply with quote Up
cant see why its stopped popping mine has always done it even with a std exhaust, i would expect issues with no flexi, you need on where the manifold ends and exhaust starts so before the cat, even if its a usniversal one on a 2 flat 2 bolt flange
project thread WIP
garage
FAQ
206 gti firedance
Project2062014
PostPosted: Fri Apr 18, 2014 1:58 pm Reply with quote Up
Got a two bolt flange on . Is tight not much play . Car vibrates a lot ,, does pop n bang a little just not as it was .
  Quick Reply
Username:
Message:
Quote the last message
