Latest: flipflap
Overall: 17140
Online Now [202]:
Visitors: 201
Today: 86504
Total: 113886366
Forums › The Car › 206 Problems › morette installation
JMT_1989
PostPosted: Fri Apr 25, 2014 10:40 am Up
Can someone help me out as I have no idea what I am doing I have a set off morette headlights with cables like this.
and these are the cables my car has after I have removed the headlight.
How the hell do I wire these in or am I missing something?
Thanks.
PostPosted: Fri Apr 25, 2014 10:46 am Up
They should just plug & play if they're the right ones for your car,
but that wiring don't look standard.
JMT_1989
PostPosted: Fri Apr 25, 2014 10:53 am Up
yeah thats what I thought hopfully someone can help
iainlovatt
PostPosted: Fri Apr 25, 2014 11:09 am Up
That wiring is standard. As it stands you car is h7 and the morettes are h4x ideally a plug and play job is using adapters. Ie h4>h7 adapters. You can hardware them using the harness that would be in your crystals,
(My Garage)
JMT_1989
PostPosted: Fri Apr 25, 2014 11:16 am Up
ohh got ya so the picture you showed me of the cables to cut is in my crystals?
iainlovatt
PostPosted: Fri Apr 25, 2014 11:35 am Up
Take the connector out of the crystals and the plugs and then get back to us on here, Smile
(My Garage)
JMT_1989
PostPosted: Fri Apr 25, 2014 11:52 am Up
ill have another look thanks mate.
PostPosted: Fri Apr 25, 2014 11:55 am Up
they should just plug straight it but make sure the wire running to the fuse box has a fuse in it, mine arrived and had no fuse so had to get another cable off here
RKOT
PostPosted: Fri Apr 25, 2014 1:06 pm Up
I've got some adapters for h7-h4 i don't need.
PostPosted: Mon Apr 28, 2014 3:24 pm Up
dont forget to put the electronic adjusters from your crystals into the morettes.
Ideally buy adapters as if you take them out your crystals they become useless - you can keep them as backup or sell for £30 +..
JMT_1989
PostPosted: Wed May 07, 2014 3:05 am Up
Can anybody tell me by looking at the below pic of my morettes which cable i need to earth?
The main headlamp is the one on the left
iainlovatt
PostPosted: Wed May 07, 2014 3:43 am Up
Middle light needs earthing. See the yellow part that has been cut, mannual add a earth cable to that.
The light on the right, Full beam headlight, one of those cables is the earth, at a GUESS it would be black, Smile
(My Garage)
JMT_1989
PostPosted: Wed May 07, 2014 3:51 am Up
can any electrial cable be used as an earth do you know? as I have some 5 amp cable spare ?
Thanks.
iainlovatt
PostPosted: Wed May 07, 2014 7:23 am Up
Thanks.
Providing its the same thickness or thicker then yes.
(My Garage)
JMT_1989
PostPosted: Wed May 07, 2014 7:48 am Up
Thanks for the help I'll have a go at it
