Online Now [454]:
Visitors: 453
Today: 143702
Total: 157165194
Forums › Tuning, Modification & Legal › Project Cars › SINFUL DESIGN GTi 180 Track Project
Go to page Previous  1, 2, 3 ... , 14, 15, 16  Next
PostPosted: Sat Apr 26, 2014 3:51 am Up
Is that shift light a bit pointless being so low?
PezHdi
PostPosted: Sat Apr 26, 2014 4:11 am Up
It's so much better with an aftermarket wheel and boss. Aye the instruments are further away but you work that out within a week. The wheel is so much lighter and you feel more in control as there's not a great big lump in the middle of the wheel and it makes you sit back in the seat a lot more.
EXL Pez
usher
PostPosted: Sat Apr 26, 2014 5:11 am Up
`the boss kit on mine is a nightmare as its too far away like std so need to get a spacer for mine which is a flat wheel unlike your dished one, im not going to reach it when buckets and harnesses are in
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
SinfulDesignCom
PostPosted: Sat Apr 26, 2014 10:44 am Up
Edward - think you are looking at the control box - the shift LIGHT itself is in the gauge pod on the drivers a pillar
Pez - totally agree - you do get used to it, and I just like the feel of a smaller wheel, and the grip makes you feel a lot more in control
Usher - I had thought of that with mine as I was finding the harnesses putting me in a position which was a little uncomfortable for the reach of the wheel. I had moved the seat a little further forward, but this meant my legs were to close to the pedal box. The joys of being 6ft3 and driving a hot hatch =)
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
usher
PostPosted: Sat Apr 26, 2014 11:17 am Up
lol i struggle at 5'10 fight distance for the legs i cant reach the wheel right distance for the wheeel im crunched up so gonna get a 20-30mm space see how it goes, wont need to reach stalks as there useles atm as ive cut the wires so gonna put them all on switches earlier than planned mind
project thread WIP
garage
FAQ
206 gti firedance
SinfulDesignCom
PostPosted: Fri Jun 20, 2014 6:45 pm Up
Latest update following fan issues. The failing of the fan circuit just bought about this change sooner as I don't like how late the fan cuts in.
Using a separate dedicated sender switch running directly to the relay (thus bypassing all the air con poo, which has been removed, and the ECU), now cuts in at 90deg and out at 82deg. Far better for a track car. I have also installed an LED in the console which lights when the fan comes on, as well as an override switch should it be required - see below;
Also took the opportunity to finally give the engine bay a good clean up and tidy the wiring etc..
Let's hope the weather is good this weekend!
Bigbenj_08
PostPosted: Sat Jun 21, 2014 4:11 pm Up
Awesome, love this car.... not in the slightest jealous Cool
Aegean Blue 1.6 16v Sport
SinfulDesignCom
PostPosted: Sun Jun 22, 2014 7:51 am Up
Thanks Ben! Good to see my work appreciated =)
benkeeganbmx
PostPosted: Wed Sep 17, 2014 10:39 am Up
This is sick and I like it a lot.
\'\'if you believe you can do something, then go and do it, because its the only way your going to get it. Make it happen\'\' - Harry Main.
uttz
PostPosted: Thu Jan 08, 2015 7:35 pm Up
SinfulDesignCom wrote:
Then with everything on the strut I put all back in place. Word of warning - do a visual check of Bilstein shocks BEFORE fitting. Part numbers were wrong. Ended up fitting drivers side to passenger side. But didn't realise until I bolted it in... So.. back out, back in with correct shock and viola!
Only ARB to do (oh, and other side!).. and then its brakes, fluid changes and done.
wish i saw this when I put in mine, popped a drop link, silly me saw the stain on the drop links too Sad
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
PezHdi
PostPosted: Wed Apr 22, 2015 3:21 pm Up
Any updates on this Mate?
EXL Pez
SinfulDesignCom
PostPosted: Wed Apr 22, 2015 5:32 pm Up
Hi guys (pez pm'd!)
Things are just being enjoyed with the motor now. Car is absolutely faultless and drives perfectly. Pulls in every gear - few traction problems in 1st and 2nd however Smile
spike_202
PostPosted: Tue Jun 23, 2015 5:12 pm Up
Could you confirm somthing for me please matt. I'm re vamping my front struts as I needed to replace a spring. Were does the washer go under the top mount or on top underneath the BIG nut?
**spike's project**
TEAM:+200bhp
SinfulDesignCom
PostPosted: Tue Jun 23, 2015 6:19 pm Up
under the big nut dude!
spike_202
PostPosted: Tue Jun 23, 2015 6:25 pm Up
So there is no washer on the shock side of the top mount ? Just under the BIG nut on the top mount. Of this is right I must of done it right 7 years ago lol.
Thanks Matt hope all is well with you mate?
**spike's project**
TEAM:+200bhp
Page 15 of 16
