Online Now [496]:
Visitors: 495
Today: 108176
Total: 156344164
Forums › The Car › 206 Problems › knocking from from O/S
le0n2014
PostPosted: Fri May 02, 2014 10:52 am Up
hi there,
im experiencing a problem with my 1.4 glx that started about 4 days ago. a knocking has started coming from my front os wheel/wheel arch area. this randomly started happening out of the blue. thus far i have changed the driveshaft (the spring in the imediate bearing housing was snapped in 2) replaced the spring and the driveshaft hoping this would fix it, no luck. so checked balljoint drop links and track rod end where tight, and they was. the drop links are about a month old and rubbers are fine. ive completely removed the front ARB just incase that had alot of play in it. still no joy. checked struts bolts are tight etc so im really stumped now.
any help would be appreciated Smile
Leon
le0n2014
PostPosted: Fri May 02, 2014 12:02 pm Up
no one???
PostPosted: Fri May 02, 2014 1:39 pm Up
le0n2014 wrote:
no one???
You waited 1 hour & 10 minutes before bumping your thread, your gonna fit in well on here
19Connor92
PostPosted: Fri May 02, 2014 2:48 pm Up
wishbone? check for wear around the pinch bolt?
commandosqueak
PostPosted: Fri May 02, 2014 3:14 pm Up
could be the disks rubbing on the pads
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
le0n2014
PostPosted: Sat May 03, 2014 5:12 am Up
MrBSI wrote:
le0n2014 wrote:
no one???
sorry dad Rolling Eyes Rolling Eyes Rolling Eyes
le0n2014
PostPosted: Sat May 03, 2014 5:19 am Up
wishbone seems fine had a bar in there and tried movin it up and down while the pinchbolt was fully tight and there werent any play in it. its a real harsh knocking like metal on metal and doesnt sound safe lol
ukskater01
PostPosted: Sat May 03, 2014 6:31 am Up
Top mount bearings ok?
le0n2014
PostPosted: Sat May 03, 2014 8:37 am Up
yea replaced them because it failed mot on 1 of them Confused not sure what to try next
DREWDEN
PostPosted: Sat May 03, 2014 12:18 pm Up
Jack the front end up, both wheels off the ground, drive through the gears, and see if knocking goes, if not it should be obvious where the noise is coming from. Laughing
206 2ltr Hdi glx 53 plate
le0n2014
PostPosted: Sun May 04, 2014 5:15 am Up
well you would of thought so wouldnt you, im still stumped as to what it could be....best check there's no sockets or ratchets kickin about in the engine bay Laughing Laughing
paulspug
PostPosted: Sun May 04, 2014 5:02 pm Up
broken shock absorber spring?
it will be noticeable when going over bumps or potholes.
