Online Now [439]:
Visitors: 438
Today: 121083
Total: 156998881
Forums › The Car › 206 Problems › 206 hatchback towbar electrics help
hlhks1
PostPosted: Tue May 06, 2014 12:00 pm Up
Hello,
Where is the best position to wire in a towbar?
Also what wires go to what, if you hava a picture of existing wireing that would be great.
Thanks all Very Happy
blah blah blah
PostPosted: Tue May 06, 2014 12:19 pm Up
I just put the cable through a grommeted hole behind the bumper and connected (cut/soldered/insulated) into the loom which is inside the rear panel. Pretty sure the hole was already there, but a while since so not 100%
Pin 1 - 289
Pin 2 - 200
Pin 3 - Earth point behind LH rear light
Pin 4 - 290
Pin 5 - 264
Pin 6 - 2101
Pin 7 - 263
No point using wire colours so you will need to look at the loom for the wire numbers
hlhks1
PostPosted: Tue May 06, 2014 5:29 pm Up
onThanks for that macca hopefully that's all il need.
blah blah blah
hlhks1
PostPosted: Sun Jun 01, 2014 10:14 am Up
Thanks again now wired up & working.
blah blah blah
