Online Now [470]:
Visitors: 469
Today: 121388
Total: 156999182
Forums › The Car › 206 Talk › Gti 180 Gearbox ID Number
Forum Index › 206 Talk
cainw1
PostPosted: Thu May 08, 2014 7:22 am Up
Where abouts on the gearbox will I find the ID number? Is it fairly obvious, as I haven't seen it when changing the oil etc
PostPosted: Thu May 08, 2014 7:32 am Up
Do you mean the serial number or model number? I think it's a BE4 5 speed box
PostPosted: Thu May 08, 2014 7:51 am Up
Whats wrong with your old box?
cainw1
PostPosted: Thu May 08, 2014 8:59 am Up
My box is whining quite loudly in gear so I am swapping it for another which I am buying off a member on here. His is off a 2003 gti 180 and mine is also a 2003 180 so I just wanted to check it was similar model number.
I know there are a few threads on here but the subject seems a little confused as to whether they are interchangeable.
PostPosted: Thu May 08, 2014 3:21 pm Up
It's on the front face of the gearbox below the battery.
Ignore the code pictured but this is where it's found.
cainw1
PostPosted: Fri May 09, 2014 12:42 am Up
Great, thanks very much for you help.
