Online Now [1313]:
Visitors: 1312
Today: 85761
Total: 151219974
Forums › The Car › 206 Talk › Taking off wheel trim?
Forum Index › 206 Talk
David1156
PostPosted: Fri May 09, 2014 9:04 am Up
Hi guys, I was wondering how the hell to remove the wheel trim on the 14" steelies. I've tried using a flat head screwdriver to get the trim away from the tire but it just won't budge. This is the wheel trim that I have:
Any help would be appreciated.
Current: Albi Blue Clio 197
K_H067
PostPosted: Fri May 09, 2014 9:10 am Up
pull it hard. They just pop off. May take some force if the trim is old as the metal ring may be rusty and stiff.
Vexs
PostPosted: Fri May 09, 2014 10:13 am Up
Like K_H said, just give it good pull, once it starts coming off work your way round the wheel loosening the rest.
My GTI 180
My Old 1.4 8v
Paul76
PostPosted: Fri May 09, 2014 3:20 pm Up
Kick it as hard as you can. If that don't work, ask one of the local yobs!
Voom voom voom
pug_206_uk
PostPosted: Fri May 09, 2014 4:33 pm Up
you could try spraying WD40 all around. I have the same wheel trims
Peugeot 206 1.4 HDI - July 2013 - Present
