Posted: Fri May 16, 2014 8:07 am |
get message saying esp/asr not working on my 06 2 litre 206 any ideas any help much appreciated
Posted: Fri May 16, 2014 8:24 am |
Get it scanned with Peugeot Planet 2000 to point you in the direction of the fault.
Could be a sensor failure, BSI bug, comm unit failure or something as simple as a loose connector.
PP2000 map
Posted: Fri May 16, 2014 8:56 am |
Will do thank you!!
Posted: Fri May 16, 2014 11:34 am |
Also a good idea to take care when driving until its fixed as you have NO working ESP or traction control
Posted: Sun May 18, 2014 4:43 am |
MrBSI wrote: |
Also a good idea to take care when driving until its fixed as you have NO working ESP or traction control | Thank you fit the warning, I've taken it to a garage that has basically told me it's an expensive job and not to bother getting it done
Posted: Sun May 18, 2014 5:17 am |
What have they said is wrong? You might be able to repair it yourself.
Posted: Sun May 18, 2014 9:24 am |
i have this problem atm too, mine go through spells of playing up, will be ok for month or so then will start doing it for a few days again.
Posted: Sun May 18, 2014 10:02 am |
macca1411 wrote: |
What have they said is wrong? You might be able to repair it yourself. | They said it's a fault in the abs system and to leave well alone!
Posted: Sun May 18, 2014 10:04 am |
not!
NorthantsBen wrote: |
i have this problem atm too, mine go through spells of playing up, will be ok for month or so then will start doing it for a few days again. | I've only had the car a week and it seems to be running fine but I don't know what happens when it's not!
Posted: Sun May 18, 2014 10:22 am |
Pezxx wrote: |
macca1411 wrote: |
What have they said is wrong? You might be able to repair it yourself. | They said it's a fault in the abs system and to leave well alone! |
So they don't really know. It could be the sensor or a cracked ring, both cheap relatively easy repairs.
Find someone close to you with PP2000 and find out what the actual fault is.
Posted: Sun May 18, 2014 10:31 am |
macca1411 wrote: |
Pezxx wrote: |
macca1411 wrote: |
Find someone close to you with PP2000 and find out what the actual fault is. | He said he put the scanner on it and that's what came up and it's an expensive fix so leave it alone it's fine as it is
Posted: Sun May 18, 2014 1:09 pm |
Pezxx wrote: |
macca1411 wrote: |
Pezxx wrote: |
macca1411 wrote: |
Find someone close to you with PP2000 and find out what the actual fault is. | He said he put the scanner on it and that's what came up and it's an expensive fix so leave it alone it's fine as it is |
Until it fails the MOT test
Find a garage / mechanic that actually knows what there talking about, this lot sound like a bunch of useless cowboys!
It needs scanning with Peugeot Planet, not some crappy Snap On scanner which most garages use.
Posted: Sun May 18, 2014 1:13 pm |
Ok i will do thank you, i need to find one in Pembrokeshire and get it sorted before the mot then
Posted: Mon May 19, 2014 12:34 pm |
Could low gearbox oil cause this warning message???
Posted: Mon May 19, 2014 12:40 pm |
I doubt it.
The ESP unit on the 206 is the same basic one that VAG have lots of issues with
Needs scanning with Planet to get the fault codes.
