Latest: heikkisj
Overall: 17126
Online Now [525]:
Visitors: 524
Today: 34424
Total: 100367380
Forums › The Car › 206 Problems › warning message
warning message
Pezxx
PostPosted: Fri May 16, 2014 8:07 am Up
get message saying esp/asr not working on my 06 2 litre 206 any ideas any help much appreciated
PostPosted: Fri May 16, 2014 8:24 am Up
Get it scanned with Peugeot Planet 2000 to point you in the direction of the fault.
Could be a sensor failure, BSI bug, comm unit failure or something as simple as a loose connector.
PP2000 map
Pezxx
PostPosted: Fri May 16, 2014 8:56 am Up
Will do thank you!!
PostPosted: Fri May 16, 2014 11:34 am Up
Also a good idea to take care when driving until its fixed as you have NO working ESP or traction control Wink
Pezxx
PostPosted: Sun May 18, 2014 4:43 am Up
Thank you fit the warning, I've taken it to a garage that has basically told me it's an expensive job and not to bother getting it done Surprised
PostPosted: Sun May 18, 2014 5:17 am Up
What have they said is wrong? You might be able to repair it yourself.
PostPosted: Sun May 18, 2014 9:24 am Up
i have this problem atm too, mine go through spells of playing up, will be ok for month or so then will start doing it for a few days again.
Pezxx
PostPosted: Sun May 18, 2014 10:02 am Up
They said it's a fault in the abs system and to leave well alone!
Pezxx
PostPosted: Sun May 18, 2014 10:04 am Up
not!
I've only had the car a week and it seems to be running fine but I don't know what happens when it's not!
PostPosted: Sun May 18, 2014 10:22 am Up
So they don't really know. It could be the sensor or a cracked ring, both cheap relatively easy repairs.
Find someone close to you with PP2000 and find out what the actual fault is.
Pezxx
PostPosted: Sun May 18, 2014 10:31 am Up
He said he put the scanner on it and that's what came up and it's an expensive fix so leave it alone it's fine as it is Sad
PostPosted: Sun May 18, 2014 1:09 pm Up
Until it fails the MOT test Wink
Find a garage / mechanic that actually knows what there talking about, this lot sound like a bunch of useless cowboys!
It needs scanning with Peugeot Planet, not some crappy Snap On scanner which most garages use.
Pezxx
PostPosted: Sun May 18, 2014 1:13 pm Up
Ok i will do thank you, i need to find one in Pembrokeshire and get it sorted before the mot then Embarassed
PostPosted: Mon May 19, 2014 12:34 pm Up
Could low gearbox oil cause this warning message???
PostPosted: Mon May 19, 2014 12:40 pm Up
I doubt it.
The ESP unit on the 206 is the same basic one that VAG have lots of issues with Wink
Needs scanning with Planet to get the fault codes.
