Just brought a set of Peugeot Vulcan alloys, no bolts included, any body know what they look like as everybody says Peugeot standard alloy bolts that, I am using on my sciroccos will do. They do not sit in the taper because they are to thick any ideas. There is not a taper in the hole or a recess for a flat headed washer to fit into, but it has got a small taper around the rim of the holes that go in about 2-3mm.
