Latest: sparrowdclxvi
Overall: 17139
Online Now [659]:
Visitors: 659
Today: 49066
Total: 112860680
Forums › The Car › 206 Problems › Oil leak
Oil leak
Toffcos
PostPosted: Tue May 20, 2014 5:00 pm Up
Should the rocker cover bolts have like a rubber washer on them to seal,
As it looks like this it were oil is leaking from
Or recommend common leak points
ukskater01
PostPosted: Tue May 20, 2014 5:45 pm Up
It's likely the rocker cover gasket has failed, quite common and cheap to replace
RichardEke
PostPosted: Tue May 20, 2014 6:06 pm Up
Hello there,
Rocker cover gasket seems the likely suspect.
On the new one just remember not to do the nuts up too tight or they like to bend and leak more oil. Least it's not the headgasket.
Regards, Richard.
Life would be easier with universal jointed arms and fingers sometimes
Toffcos
PostPosted: Wed May 21, 2014 5:51 pm Up
Thanks for input. I'll check the new gasket.
