Latest: Andyblue64
Overall: 17123
Online Now [488]:
Visitors: 487
Today: 126578
Total: 98495263
Forums › The Car › 206 Talk › Blocked Water Jet...
Mlachhab
PostPosted: Tue May 27, 2014 5:17 am Up
Hi,
Long story short I was topping up my windscreen fluid a few weeks ago, and one of my pals dropped their cigarette down the tube. A couple days ago the jets stopped spraying out water. Is there a filter located anywhere where I'd find it to clean this out?
PostPosted: Tue May 27, 2014 6:24 am Up
I would take washer bottle and pump out and inspect as probably all clogged up from the cigarette.
Could even take pipes off pump and if it pumps water with them off then the pipes after pump are clogged.
Mlachhab
PostPosted: Tue May 27, 2014 7:40 am Up
Where about would I find that? Would I just need to trace through the piping?
PostPosted: Tue May 27, 2014 11:22 am Up
Its up inside the drivers side wing behind the bumper, you need to remove the plastic arch liner.
Most likely find the cigarette filter has blocked the pump intake.
sean.r.steward
PostPosted: Tue May 27, 2014 4:08 pm Up
Its a peugeot not an ashtray lol
