Latest: DanDan17
Overall: 17128
Online Now [56]:
Visitors: 55
Today: 5665
Total: 100566402
Forums › The Car › 206 Problems › alternator not charging battery
geordiejames
PostPosted: Tue May 27, 2014 2:30 pm Up
My alternator is not charging my battery on my 03 1.1 pug 206, when i checked the alternator there is 13.5v coming out of it at the main cable so i cant understand why its not charging the battery
bodieanddoyle
PostPosted: Tue May 27, 2014 2:37 pm Up
Could be the battery isn't taking the charge. Really I'd like to see over 14v at idle no load. Get a proper battery test done. I have had a failing battery pass a test but only the one. Also check your earth connections and the live on the alternator isn't corroded.
drives a little green deep fat fryer. 1.4 hdi sw.
You should see around 14.4 volts output from a good alternator with lights, heater blower & heated rear window on.
13.5 volt output just isn't enough to charge the battery satisfactorily.
sean.r.steward
PostPosted: Tue May 27, 2014 3:56 pm Up
Yep load it up. And then check it
geordiejames
PostPosted: Wed May 28, 2014 2:35 am Up
So if the alt is only putting out 13.5 or so, what is stopping it charging the battery?
bodieanddoyle
PostPosted: Wed May 28, 2014 1:48 pm Up
Rectifier. Poor contact surfaces. Battery in poor state of health.
geordiejames
PostPosted: Wed May 28, 2014 4:19 pm Up
I charged the battery in the house the other day and it seem to hold charge should i get it checked
geordiejames
PostPosted: Wed May 28, 2014 4:20 pm Up
What is a rectifier?
bodieanddoyle
PostPosted: Wed May 28, 2014 4:59 pm Up
I'd get it checked to be safe. Some motor factors will give the battery a digital health check nowadays. Rectifier is on the back of the alternator. Stabilises output voltage and changes ac to dc current. Not generally available separately but mostly the part that fails in an older style alternator.
geordiejames
PostPosted: Thu May 29, 2014 2:06 am Up
I will get the battery checked, would u say new alternator, earths seem ok
