Latest: DanDan17
Overall: 17128
Online Now [109]:
Visitors: 108
Today: 33451
Total: 100553343
Forums › The Car › 206 Problems › Steering wobble
Steering wobble
woodthorpe1717
PostPosted: Tue May 27, 2014 5:32 pm Up
Right I've had a look on the other posts and I can't find a salution or the same issue so here goes.
I have a 53 plate 206 2litre HDI SW (my super family wagon)
Anyway, if I'm travelling my speed (even <10mph) my steering wheel wobbles. Not just a little bit either, it goes maybe inch to 2 inch from side to side.
Steering fluid full, wheels balanced, identical tyres, no bulges etc, tracking bang on, recently had 2 new CV joints (issue started before fitting).
I DO have an issue with pump as when I go round a long bend or roundabout my steering pulls back, this can only be described as like a force feedback arcade steering wheel.
Could both symptoms be connected? Is it possible to bleed pump system and how?
I've tried to give as much info as I can but if I've forgotten something please ask because I need this sorting and garages cost lots of pennies.
Cheers all
1.9 Diesel NON turbo.\r\nWho needs power?!
denners
PostPosted: Tue May 27, 2014 5:47 pm Up
have you checked your wishbone bushes? mine went a while ago and it was like being in a the middle of a tug of war until I changed them, other than that not too sure bud
woodthorpe1717
PostPosted: Wed May 28, 2014 2:33 am Up
Thanks denners. Will check that shortly.
woodthorpe1717
PostPosted: Wed May 28, 2014 10:45 am Up
Ok so all bushes are fine. Can only think it has something to do with steering pump. Can these be bled to remove possible air pockets?
woodthorpe1717
PostPosted: Wed May 28, 2014 10:57 am Up
silverpug108
PostPosted: Wed May 28, 2014 1:39 pm Up
I had something similar, had the lower wishbones , the top suspension bearings replaced (which had totally rusted and seized) , and the steering rack replaced.
woodthorpe1717
PostPosted: Fri May 30, 2014 12:37 pm Up
Is the steering rack a big job? And can it just go like this without prior symptoms?
