Online Now [214]:
Visitors: 213
Today: 83805
Total: 156320141
Forums › The Car › 206 Problems › when under harsh acceleration revs stick
standardgt180
PostPosted: Mon Jun 09, 2014 4:59 am Up
hello anyone know why my revs stick when harsh accelerating , i have a 2004 gti 180 i have cleaned the throttle boddie out n moved the mat ? cheers
PostPosted: Mon Jun 09, 2014 5:20 am Up
Not sure if it will be cable or electronic throttle.
If cable, possibly the cable is sticking in the outer sleeve or the spring on the throttle body is weak.
If electronic, could be the sensor on the pedal or the motor on the throttle body playing up.
PostPosted: Mon Jun 09, 2014 11:19 am Up
It will be electronic fly by wire throttle set up as it's a GTI 180 which has ESP fitted.
PostPosted: Mon Jun 09, 2014 2:47 pm Up
try resting the throttle body,if it works then you will save pounds,if not,then a new throttle body needed.
