Online Now [59]:
Visitors: 58
Today: 46080
Total: 116782215
Forums › The Car › 206 Problems › 1.9D Cooling problem
dimef
PostPosted: Mon Jun 09, 2014 6:44 pm Up
Hi All,
My 206 is 1.9D with AC. The problem that I'm facing over a year ago is the Cooling problem with first stage of FAN.
The first stage of fan is turning on middle the second and third step-line after 90C.
I've tried to replace the sensor (blue), fan resistor but nothing helped.
The 2nd fan speed is working properly when I'll remove the wiring from the blue sensor(it starts with first stage, shortly after few seconds the 2nd Fan stage is running) or when I'll turn on my AC.
any ideas,
thanks!
PostPosted: Tue Jun 10, 2014 7:34 am Up
Sounds fine. Dervs don't tend to overheat unless sat still. They generally run about 80-90
dimef
PostPosted: Sat Jun 14, 2014 3:48 pm Up
Hi
I think it is not running fine.
I remember the first fan stage kept the temp. around 90C and it was running normal when there was
traffic jam and hot summer temperatures.
When I bought it, on hot summer temperatures and traffic jams, the temp. was running up to 95C then the fan was on until little below 90C.
Now the first fan speed is running on 115-120C which I think is wrong.
any help is appreciated
thanks
PostPosted: Sun Jun 15, 2014 5:24 am Up
I'd try temp sensor then if the fans are still working.
dimef
PostPosted: Sun Jun 15, 2014 8:02 am Up
This one I already replaced: 1.9 Sensor (EBAY)
still on 115 first speed Sad
also I replaced the resistor
