Latest: williamekstrom
Overall: 17124
Online Now [76]:
Visitors: 75
Today: 1549
Total: 99333602
Forums › The Car › 206 Problems › rear of car lower on driver side
pewter1
PostPosted: Fri Jun 06, 2014 12:12 pm Up
hi
i'm new to this forum and this is my first post,
my problem is that the rear of the car is lower on the driver side by about half an inch than the passenger side, the rear suspension is also really hard and had no give in it whatsoever.
Anyone know what could be causing this?
PostPosted: Sat Jun 07, 2014 2:37 pm Up
is your car is standard or lowered?
PostPosted: Sun Jun 08, 2014 1:53 am Up
Back axle is knackered.
DREWDEN
PostPosted: Wed Jun 11, 2014 6:04 pm Up
Out of interest, is the steeing playing up at all.
Think its quite common for the drivers side to sag a bit, when you take into consideration the fuel tank and obviously the drivers weight taking impact on that side all the time.
206 2ltr Hdi glx 53 plate
PostPosted: Wed Jun 11, 2014 6:07 pm Up
?? Fuel tank is centered, and you'd have to be a fair weight to affect the suspension. You might as well say the passenger side will sag because of the gearbox.
Nath189
PostPosted: Thu Jun 12, 2014 4:21 am Up
I had similar problem turned out to be the bolt that holds the anti roll bar plate on n/s had snapped
sean.r.steward
PostPosted: Thu Jun 12, 2014 2:54 pm Up
that can happen lol.
sean.r.steward
PostPosted: Thu Jun 12, 2014 2:55 pm Up
Maybe someone put new bearing in and got 1 side a spline out
