Online Now [393]:
Visitors: 392
Today: 29932
Total: 156908352
Forums › The Car › 206 Problems › Drum Brakes
Drum Brakes
GTSX
PostPosted: Mon Jun 16, 2014 3:14 am Up
Hi,
I have a job to sort out on a 206 with drum brakes. To save a long story I have a pile of pieces both new and old from someone stripping it all down.
I would really like some photos of what it should look like so I can put it all back together. Also how does the abs work on this system?
PostPosted: Mon Jun 16, 2014 3:35 am Up
I've got this one. It's from a 1.4 non ABS with Bosch brake system
Think with ABS the sensor comes through the back plate and the drum has the teeth cut into it around the hub area
DREWDEN
PostPosted: Mon Jun 16, 2014 1:42 pm Up
http://public.servicebox.peugeot.com/docapv/affiche.do?ref=T1F442G44A&refaff=T1F442G44A&idFct=FCT0039
** Link edited by VorTechS - make sure you use the URL tags to paste in a website link and it shouldn't mess up like this Wink
206 2ltr Hdi glx 53 plate
GTSX
PostPosted: Mon Jun 16, 2014 3:36 pm Up
Cheers Macca, do you have a close up shot of the top left corner for the auto adjuster set up?
Drewden, I can't get in on that site.
Can anyone else help?
DREWDEN
PostPosted: Mon Jun 16, 2014 4:31 pm Up
Sorry about that, when i coppied and pasted the url for the page, it was ok in preview, for some reason it has reverted back, maybe i am doing something wrong.
VorTechS
PostPosted: Tue Jun 17, 2014 2:59 am Up
Staff - Vortechs
Edited the link above, but you will need a username and password to access the content.
GTSX
PostPosted: Wed Jun 18, 2014 12:36 pm Up
Thanks for the help so far guys. Smile
A new problem now though. The ABS works on a magnetic slip ring that fits on to the centre boss of the brake drum/hub assembly. These have got damaged on the original items removed and they are not on the new drum/hub assembly (pattern part).
Peugeot couldn't come up with a part for this magnetic ring on a 206, it is only shown as a complete item drum/hub. I have looked on Service box (thanks to Drewden) and can't find it either. The 207 part number comes up as 4549 19 "Anti lock wheel radial target".
Does anyone know if this fits on a 206 or can someone give me the correct part number????
PostPosted: Wed Jun 18, 2014 4:27 pm Up
Think you can only buy them as part of the drum. Try ECP as they have always got some sort of promotional discount going.
206Tom
PostPosted: Thu Jun 19, 2014 11:25 am Up
Yeah, its part of the drum assembly unfortunately.
Think you're covered for pics now but as I've just done mine heres another lol.
GTSX
PostPosted: Fri Jun 20, 2014 1:56 am Up
Cheers Tom. Smile
I found some new target rings on German e-bay and they're in the post Wink
