Latest: Andyblue64
Overall: 17123
Online Now [109]:
Visitors: 108
Today: 23499
Total: 99248314
Forums › The Car › 206 Problems › side light and tail light out
JMT_1989
PostPosted: Thu Jun 19, 2014 5:40 am Up
Hoping somone can help my tail light and front side light have stopped working on the passanger side.
I have checked the bulbs and even replaced the rear light cluster but no luck I have looked at a grid online for the fuses but the fuse it states is F35 but my fuse box dont go that high any advice before I pay a garage to find it?
Thanks.
PostPosted: Thu Jun 19, 2014 7:02 am Up
Yours is multi-plexed.
Multi-plexed fuse list
Although it will probably be of no use as off the top of my head, there is no actual fuse just for sidelights, it comes through the BSI. Will see if I can dig out the wiring diagram for you. Think I put it up on here a few weeks ago.
EDIT
JMT_1989
PostPosted: Thu Jun 19, 2014 7:42 am Up
So I'm guessing this is quite a serious problem then will I need the bsi replaced?
DREWDEN
PostPosted: Fri Jun 20, 2014 5:42 am Up
If you go to page 3 at the bottom, Username Jooo did a thread same problem, outcome was successful.
Smile
206 2ltr Hdi glx 53 plate
