Latest: S2cgm
Overall: 17178
Online Now [161]:
Visitors: 160
Today: 30617
Total: 136560631
Forums › The Car › Solved 206 Problems › 1.1 not starting -SOLVED
Go to page Previous  1, 2
PostPosted: Sun Jun 15, 2014 2:33 pm Up
MrBSI wrote:
Timon2210 wrote:
You are most welcome David,try to get VARTA,it's the best battery,then comes BOSCH,
There exactly the same just with different branding.
Varta make the batteries for Bosch Wink
Thank you for the info. my friend,I didn't know this Wink
David1156
PostPosted: Wed Jun 18, 2014 10:29 am Up
Quick update guys, it was indeed the battery. Quite relieved it wasn't anything serious. You guys were right as always Smile I will be going for a bosch battery. Which one of the following would you recommend?
Bosch S3 Battery - CCA 480, Ah 56
Bosch S4 Battery - CCA 540, Ah 60
Bosch S5 Battery - CCA 610, Ah6
I have a feeling the last one is overkill and the second one is the best.
Current: Albi Blue Clio 197
David1156
PostPosted: Thu Jun 19, 2014 10:02 am Up
Got the S4 now all is well. Thanks once again everybody Smile
PostPosted: Tue Jun 24, 2014 3:54 pm Up
sorry that I didn't reply on which battery to chose for your car,but the one you got is the great :),glad you got it fixed :),enjoy the drive now Wink
Sneakyboris86
PostPosted: Wed Jun 10, 2015 7:30 pm Up
Hi, I'm very new to this! I've really had enough of my bloody 206 1.1, it's an absolute pain to start, 5/6 attempts, then it cuts out a few times before driving fine, then it'll cut out approaching junctions etc... And ideas as to the solution? I've had plugs, filters, battery terminal, fuel pump changed! I've bought a brown relay that I have no idea where to find it! Please please please help me
David1156
PostPosted: Thu Jun 11, 2015 1:32 pm Up
Hi there, It would be best if you start your own thread as it will get more views since this one is in the solved section. Have you possibly tried cleaning the throttle body or seeing if there are any fault codes stored? Has all the work been done by a mechanic or yourself? I would also recommend searching the forum as chances are someone else has already experienced the same problem as you.
Page 2 of 2
