Online Now [345]:
Visitors: 344
Today: 105380
Total: 155708361
Forums › The Car › 206 Problems › injector control 4 open circuit or short to earth
Antknee
PostPosted: Tue Jun 17, 2014 6:33 am Up
Scanned with planet and got this, can anyone advise? It's a 1.4 petrol 2002
Cheers
Antknee
PostPosted: Tue Jun 17, 2014 10:14 am Up
This is an intermittent fault btw, would it flag as intermittent if the injector was just getting blocked?
PostPosted: Tue Jun 17, 2014 2:56 pm Up
as it's intermittent fault,then there is nothing to worry about,check the injectors plugs,and make sure all if fixed well.
PostPosted: Wed Jun 18, 2014 5:20 am Up
Probably the injector failing (one closest to the cambelt). Check the resistance over the two pins and let me know what your getting
Antknee
PostPosted: Fri Jun 20, 2014 11:47 am Up
Cheers pal all injectors are are testing at 12.6
