Online Now [1990]:
Visitors: 1989
Today: 190403
Total: 152227216
Forums › The Car › 206 Talk › wheel spacers and bolts
Forum Index › 206 Talk
gtijames22
PostPosted: Mon Jun 23, 2014 11:04 am Up
just wondering if anyone can help me with an issue, gonna get 15mm spacers so that i can use the 406 brembos with my 180 alloys, does anyone know if the 45mm extended flat bolts will be long enough or does anyone know where i can get longer ones, ive only checked fleabay so far.
any help appreciated.
GTI 180 JIM
Targa180
PostPosted: Mon Jun 23, 2014 5:17 pm Up
I have this brembo upgrade and spacers fitted to my RC, what are the 45mm "flat bolts" your referring to, ill go measure bits iff i need to help you out.
Cheers Matt
gtijames22
PostPosted: Mon Jun 23, 2014 9:38 pm Up
thanks for the reply matt, i know the standard bolts are 35mm but the only extended non tapered bolts i can find are 45mm, so im 5mm short. need to try and get a hold of longer ones, do you use aftermarket alloys because if so the tapered bolts are no problem to acquire. if not can you measure your stuff for me, would really help alot mate.
thanks.
GTI 180 JIM
