Latest: heikkisj
Overall: 17126
Online Now [64]:
Visitors: 63
Today: 15810
Total: 100278142
Forums › The Car › 206 Problems › Lambda sensors
Lambda sensors
Anthonys206
PostPosted: Mon Jun 23, 2014 2:44 pm Up
Hi guys, I have ANOTHER problem with my 206. I had a fault code of po130, now I thought it was because I had previously bought the wrong sensor ( I bought a white plugged sensor instead of blue) anyways I changed the sensor and connected everything back up again, cleared the fault code and started it up. All seemed fine. Put the code reader back on it today and would you believe that I have the same fault code plus po136. I've checked the wiring as far back as I can and there seems to be no problems. So what's wrong now?
Anthonys206
It's a 52 plate 1.4
