Latest: DanDan17
Overall: 17128
Online Now [65]:
Visitors: 64
Today: 14272
Total: 100574972
Forums › The Car › 206 Problems › Under heating problem *help please*
Nath189
PostPosted: Wed Jun 25, 2014 6:01 am Up
Hi hoping anyone can help get rid of this annoying fault. Ok so it a 2.0 hdi 2002 150,000 miles. My problems first started a few months ago when it started to over heat and blowers was cold found the water pump inpella had collapsed so replaced the pump with one that has a metal inpella and also changed the thermostat, all was well untill I decided to take one of the pipes of the side of the header tank and remove the spring clip to help a mate out but pulled the plastic lug off! So I just put the pipe into the tank and left the cap off. Drove like this for a few weeks till pay day and brought a 2nd hand one. So fitted this filled with water and bleed but noticed the temp wouldn't get above 65-70 while driving and takes an hour just idling to reach 90 so changed the Coolant temp senor, filled with coolant and beld but still the same problem. Also the top hose seems to get hot about 64c but doesnt feel like it pressurising. Any ideas anyone?
Sorry is so long wanted to make sure enough info was there.
cartoonhead
PostPosted: Wed Jun 25, 2014 8:06 am Up
70 is about right for a 2.0 HDI engine
Nath189
PostPosted: Wed Jun 25, 2014 10:33 am Up
Oh ok the water pump must of been on its way out then when I brought the car.
Cheers
