Online Now [309]:
Visitors: 308
Today: 128532
Total: 156234539
Forums › The Car › 206 Problems › Torque wrench setting
GTSX
PostPosted: Thu Jun 26, 2014 7:11 am Up
Hi,
Can someone please tell me the torque wrench setting for...
4 Rear subframe bolts
Rear hub nuts (drum brake with ABS)
Wheel nuts
PostPosted: Thu Jun 26, 2014 9:19 am Up
GTSX wrote:
4 Rear subframe bolts 110Nm
Rear hub nuts (drum brake with ABS) 200Nm
Wheel nuts 90Nm
GTSX
PostPosted: Thu Jun 26, 2014 2:57 pm Up
Thanks Macca
DREWDEN
PostPosted: Thu Jun 26, 2014 4:15 pm Up
Hi GTSX, see you have changed your rear axle like myself yesterday in fact, i am a bit confused with the rear drums, the original drums from the car has 1 with ring for the ABS and 1 without magnetic (different) owned car from nearly new and original.
The second hand axle came without rings, but what i have searched are magnetic, and the sensors take a magnetic reading, fitted these as they are fairly new.
ABS working ok no problems, just wondered why peugeot fitted different ones.
206 2ltr Hdi glx 53 plate
