Latest: lio94
Overall: 17181
Online Now [163]:
Visitors: 162
Today: 115898
Total: 140592752
Forums › The Car › Request a how-to › front wing removal
front wing removal
Forum IndexRequest a how-to
Dansinclair11
PostPosted: Fri Feb 03, 2012 6:56 am Reply with quote Up
please can someone explain how to remove the front wings? im stuck Sad
dan
PostPosted: Fri Feb 03, 2012 7:13 am Reply with quote Up
its fairly straight forward, you need to remove your headlights and bumper first
karimali831
PostPosted: Fri Feb 03, 2012 7:51 am Reply with quote Up
you need the right size/tools for the job.
this may help: www.peugeot206cc.co.uk...ag0jf3.htm
206 GTI 180
Dansinclair11
PostPosted: Fri Feb 03, 2012 9:56 am Reply with quote Up
thankyou
dan
PostPosted: Fri Feb 03, 2012 9:59 am Reply with quote Up
10mm socket & spanner, and a screw driver you can do the do with, Wink
PostPosted: Fri Feb 03, 2012 10:13 am Reply with quote Up
You dont need to remove the headlight if you have the correct tools.
You dont need to remove the bumper either, its only the corner bolt that attaches it to the wing.
KevinL64
PostPosted: Mon Jun 30, 2014 7:26 am Reply with quote Up
I've just taken the nearside wing off my daughters '03 plate 206 style. There are five bolts holding the wing on, two on top of the wing (one of which holds the bonnet stay), and two accessed in the void behind the headlight. The Fifth bolt is behind the wing near the door pillar and can only be accessed once the other four are undone and the wing is free from the locator pins on the scuttle panel. This fifth bolt doesn't have to be removed as the wing simply hangs on it. I found I had to remove the headlight to get to the bolt that holds the wing to the scuttle and the other bolt is awkward to get to, but I found using a universal joint on a long extension allowed me to undo and refasten it. Once all the bolts are undone, you can lift the wing vertically off the locating post at the bottom of the door pillar.
MrWhite
PostPosted: Mon Jun 30, 2014 3:16 pm Reply with quote Up
this is a life saver im just about to replace the wing after me and Merlot got into a little fender bender on a mini round about. 13 year old pug vs 63 plate Skoda pahaha
My 206 Project Thread
  Quick Reply
Username:
Message:
Quote the last message
