Latest: Mr-Koekwaus
Overall: 17125
Online Now [297]:
Visitors: 296
Today: 42284
Total: 99467776
Forums › The Car › 206 Problems › Cam Belt Tension
Cam Belt Tension
TattyWater
PostPosted: Sun Jul 06, 2014 3:35 pm Up
Need to change the head gasket on my 1.1 1999 206. So going to do the Timing belt and water pump at same time.
Haynes manual says need Peugeot electronic tension measure tool, how do I get the correct tension without this tools, it says 90Deg turn on tensioner is about right, but check at dealer ??
Any advise appreciated.
Cheers
Mike
bbsrs2011
PostPosted: Sun Jul 06, 2014 5:51 pm Up
It should be an automatic tensioner.
You should be able to just crank it back with a wrench or a small breaker bar and then the belt should just slide off.
Hope this helps
TattyWater
PostPosted: Mon Jul 07, 2014 1:34 am Up
I thought it was the just Aux belt that was automatic tensioner ?
bbsrs2011
PostPosted: Wed Jul 09, 2014 2:25 pm Up
Not that I can remember.
I might be wrong though as I haven't changed the cambelt in ages
CliffordGarrett
PostPosted: Sun Apr 26, 2015 4:36 am Up
so what happened? Did you change the belt? How was it re-tensioned?
