Online Now [250]:
Visitors: 249
Today: 69690
Total: 156681613
Forums › The Car › Solved 206 Problems › ISSUE WITH MY BLOODY LIGHTS
Forum Index › Solved 206 Problems
daz601
PostPosted: Wed Jul 09, 2014 4:29 pm Up
When my keys are in the position just before you turn the engine on, the lights on the stalk work perfect, OFF, sidelamps, main but when the engine goes on the lights wont turn off. you have main lights in the off position then twist to sidelamps and main again.
WHATS UP???? anyone had this?
PostPosted: Wed Jul 09, 2014 4:34 pm Up
Does the car have a rain & LIGHT sensor fitted behind the rear view mirror?
What year of 206 is it as there are 2 totally different electrical systems used but from the fault I guess we are talking multiplexed 206.
1) Either the light sensor is faulty - this will default the headlamps to ON all the time the engine is running.
2) Someone has turned the day time running light setting ON in the BSI configuration set up.
3) You have lost a CAN node - this will also put the headlamps ON.
If it does have the light sensor fitted then turn the auto headlamps OFF & see if they then behave themselves.
daz601
PostPosted: Wed Jul 09, 2014 5:04 pm Up
SOLVED, WAS JUST THE AUTO LIGHT FEATURE. TODAY I HAD TO DISCONNECT MY BATTERY SO THIS MUST HAVE AUTOMATICALLY PUT IT IN 'AUTO LIGHT MODE'
TO PUT THIS BACK TO NORMAL I JUST TURNED THE KEY INTO THE FIRST POSITION (ACCESSORIES) AND PRESSED THE AUTO IN FOR 4 SECONDS UNTIL I HEARD A BONG
THANKS MATE
PostPosted: Thu Jul 10, 2014 1:23 am Up
Multiplexed 206 needs to be shut down & rebooted correctly.
Disconnecting / connecting the battery without following the correct proceadure risks corrupting the BSI software or at worse frying the BSI unit.
PostPosted: Thu Jul 10, 2014 2:51 am Up
THANKS MATE
Ali_H
PostPosted: Thu Jul 10, 2014 7:58 am Up
If it's not bold type, it's caps lock.
Glad your lights are fixed, now maybe you could sort out your keyboard.
kurtis wrote:
daz601
PostPosted: Thu Jul 10, 2014 9:31 am Up
Sorry guys I wasn't aware of the law that says things cannot be written in caps.
