Latest: Andyblue64
Overall: 17123
Online Now [137]:
Visitors: 136
Today: 66518
Total: 99291242
Forums › The Car › 206 Problems › Oil breather pipe split
Tolkienfan001
PostPosted: Fri Jul 18, 2014 3:38 am Up
Trade Rating: +13
Can someone please get me the part number(s)? I can't seem to get into service box.
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Fri Jul 18, 2014 10:39 am Up
Does the pipe have ends that can be cut off the main pipe? If so then just re use the connectors and link them with some silicon hose.
Tolkienfan001
PostPosted: Fri Jul 18, 2014 11:00 am Up
Trade Rating: +13
Good idea thanks
2005 1.4 16v Sport
