Online Now [335]:
Visitors: 333
Bots: 2
Today: 91922
Total: 157281248
Forums › The Car › 206 Problems › Hard start when cold-happens occasionally
hamed206
PostPosted: Wed Jul 16, 2014 11:02 am Up
Engine will turn but won't start unless you try for 10-15 times! It happens when you park the car for 6 hrs or more. But this doesn't happen always, it happened only 2 times in 1 month.
Any ideas?
My fuel pump, fuel filter, coil pack, spark plugs, are all new.
Hamed
PostPosted: Wed Jul 16, 2014 11:39 am Up
What condition is the battery in?
hamed206
PostPosted: Wed Jul 16, 2014 8:33 pm Up
Battery is only 6 months old. I'm not suspecting the battery because the engine turns and the sound of the turn is fine (not weak).
Hamed
Targa180
PostPosted: Wed Jul 16, 2014 11:15 pm Up
I thought this was normal in cold weather? My 180 does this every winter. coughs n farts around for 5 seconds then a rough idle til warm
Danw_VVT
PostPosted: Thu Jul 17, 2014 2:57 am Up
What about the leads have you check them?
When was it last serviced?
hamed206
PostPosted: Thu Jul 17, 2014 9:36 pm Up
Actually, we don't have a cold climate in Egypt now! It is 30C in the morning!
Hamed
hamed206
Spark plugs extensions have been replaced with the coil 2 months ago.
Hamed
hamed206
PostPosted: Thu Jul 17, 2014 9:37 pm Up
Could the MAP sensor make such an issue?
Hamed
hamed206
PostPosted: Fri Jul 18, 2014 8:11 pm Up
Today it happened when the car was not cold. I tried to turn the engine, but it didn't turn after several trials. So I tried an old MAP sensor, lucky it worked! Sounds that the problem has been sorted. Will need to test again for more few days.
Hamed
