Latest: lio94
Overall: 17181
Online Now [341]:
Visitors: 340
Today: 50164
Total: 141133508
Forums › The Car › 206 Talk › air con condenser
air con condenser
PostPosted: Sat Jul 26, 2014 4:04 pm Up
Been to get my air conditioning re gassed today but turns out condenser is leaking so needs replacing so they couldn't do it.
My question is 1 - are all 206 condensers the same? 2 - are they easy to replace (eg pipes bolt to condenser or something else)
Ben Smile
iainlovatt
PostPosted: Sun Jul 27, 2014 3:26 am Up
Yes, did it last year. I removed front end in order to get easy access. Removed fan, undid the two bolts of the pipes on the ac. Lift it out. swap over for the new parts and put it back together, didn't take very long. Very straight forward to do..
(My Garage)
ukskater01
PostPosted: Sun Jul 27, 2014 4:00 am Up
Make sure there's no gas in it!
PostPosted: Sun Jul 27, 2014 4:04 am Up
Kwl kwl cheers Smile
There is a leak so no gas. Plus there machine will have removed any if there was any left.
You can see the pink dye its not a small leak lol
