Latest: Andyblue64
Overall: 17123
Online Now [275]:
Visitors: 274
Today: 58868
Total: 98146068
Forums › The Car › 206 Talk › How much tint do I need...?
SamNI96
PostPosted: Sat Jul 26, 2014 7:38 pm Up
I know it's not an easy question to answer, but if I were to get a roll of window tint (seems 76cm x 6m is the most common) how many rolls would I need for the rear 3 windows only (3 door)?
Thanks as always guys and gals.
PostPosted: Sun Jul 27, 2014 2:19 am Up
Have you got a tape measure?
Measure the longest point of each window and add them up.
**Top Tip** Just measure one of the side windows and double it, it saves time and effort
PostPosted: Sun Jul 27, 2014 5:35 am Up
Rocket science it aint. Why does a 206 need bin bags in the windows anyway?
