Latest: DanDan17
Overall: 17128
Online Now [393]:
Visitors: 392
Today: 61042
Total: 100661400
Forums › The Car › 206 Talk › AIRCON BY PASS?
AIRCON BY PASS?
MURPHYSSSS
PostPosted: Sun Jul 27, 2014 7:47 am Up
Hi newbe here to cut a long story short i have got a wire from my battery to air con compressor and it works lovely cold air now the question is could i leave it on like this whilst the hot weather is on or do you think it would over heat? 206 1.4 x reg thanks shaun Question
206-GTi
PostPosted: Sun Jul 27, 2014 8:53 am Up
What's wrong with the original zircon wiring loom? Not sure I fully understand the question.
GTi - Black - 2002
MURPHYSSSS
PostPosted: Sun Jul 27, 2014 9:31 am Up
Hi thanks for your reply, When i switched on aircon it lit up then i got a "clicking noise from my AIR CON REGULATOR MODULE and so replaced that then i went and got a full regas from garage a full job, got home still the same .So i had find out if compressor had broke or another switch ,wired 12v from battery to ac with the wires from it and it clunked and works .so now i have it on direct all the time and wondered what would happen if i left it on untill i get switch sorted? thanks shaun
PostPosted: Sun Jul 27, 2014 10:58 pm Up
If it's running without the key turned on it's going to run your battery down.
PostPosted: Mon Jul 28, 2014 5:34 am Up
This sounds like a disaster waiting to happen, if it doesn't work get it fixed properly! Dont guess and do it yourself!
PostPosted: Mon Jul 28, 2014 5:36 am Up
Btw check your pressures, you might have a big leak causing too little pressure which cuts out the compressor. If you sont have enough pressure the oil wont move around in the system which will damage it!
MURPHYSSSS
PostPosted: Mon Jul 28, 2014 11:43 am Up
Thanks for your help, this where am at .Now i know my air con is fully gassed and no leaks , i have taken the lead from car to compressor and put a volt tester on it . Now when i start car everything is normal ,now with voltmeter on i switch on air con , i get power through on 1, 2 on blower, then after a 2 min or so i hear clicking from my AIR CON REGULATOR MODULE and the volts jump all over the place .So what could cause such a disruption in power ? this also hapens if i rev up engine any help please thanks
