Posted: Sun Jul 27, 2014 7:47 am |
Hi newbe here to cut a long story short i have got a wire from my battery to air con compressor and it works lovely cold air now the question is could i leave it on like this whilst the hot weather is on or do you think it would over heat? 206 1.4 x reg thanks shaun
Posted: Sun Jul 27, 2014 8:53 am |
What's wrong with the original zircon wiring loom? Not sure I fully understand the question.
Posted: Sun Jul 27, 2014 9:31 am |
Hi thanks for your reply, When i switched on aircon it lit up then i got a "clicking noise from my AIR CON REGULATOR MODULE and so replaced that then i went and got a full regas from garage a full job, got home still the same .So i had find out if compressor had broke or another switch ,wired 12v from battery to ac with the wires from it and it clunked and works .so now i have it on direct all the time and wondered what would happen if i left it on untill i get switch sorted? thanks shaun
Posted: Sun Jul 27, 2014 10:58 pm |
If it's running without the key turned on it's going to run your battery down.
Posted: Mon Jul 28, 2014 5:34 am |
This sounds like a disaster waiting to happen, if it doesn't work get it fixed properly! Dont guess and do it yourself!
| Team Impossible Possible
Posted: Mon Jul 28, 2014 5:36 am |
Btw check your pressures, you might have a big leak causing too little pressure which cuts out the compressor. If you sont have enough pressure the oil wont move around in the system which will damage it!
Posted: Mon Jul 28, 2014 11:43 am |
Thanks for your help, this where am at .Now i know my air con is fully gassed and no leaks , i have taken the lead from car to compressor and put a volt tester on it . Now when i start car everything is normal ,now with voltmeter on i switch on air con , i get power through on 1, 2 on blower, then after a 2 min or so i hear clicking from my AIR CON REGULATOR MODULE and the volts jump all over the place .So what could cause such a disruption in power ? this also hapens if i rev up engine any help please thanks
